07-18-2013 09:44 AM - edited 03-18-2019 01:28 AM
What'ss the diference between high definition and premium resolution option key in sx20?
Thanks in advance.
07-18-2013 10:11 AM
$3465 :-)
07-18-2013 10:26 AM
Hi ,
Probably Oleksandr have given you teh actual difference of amount that will be slipped out from your budget
here is the technical detail just in case you were looking for
HD
PR
regards
Ravi kr
07-18-2013 07:17 PM
If you have purchased PR key then you do not require HD key for codec .
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys MultiSite: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "true"
*s SystemUnit Software OptionKeys HighDefinition: "false"
*s SystemUnit Software OptionKeys DualDisplay: "true"
Kind regards,
Dharmmesh
