Display two laptops to two monitors with Room Kit Pro?
Scott Nieto
I have a Codec Pro with outputs to three displays and inputs from two laptops. Is it possible to display (not share) two laptops to two of the displays?
Jonathan Schulenberg
Yes but only out of a call (without invoking the compositor matrix xAPI). If the laptops are connected to two different HDMI ports you should be able to select both for local preview.
Yes, if you configure the inputs as PC content inputs, you will then be able to chose which screen to share each on when they are connected.  The device will do this natively unless you have some other config on the codec which prevents this from happening.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
