02-27-2019 04:00 PM
In the deployment B2B, Do I need public root CA for the certificates of EXP E to communicate with other companies?
Regards.
03-04-2019 07:11 PM
04-04-2019 02:49 PM
Thanks you Jon,
I am trying to understand. If I want coneccion with TLS, I need to install de CA from Federation and viceversa?
What happend if a want to deploy 3-port Firewall DMZ Using Single Expressway-E LAN Interface? In this case I do not need to share certificates with any one right? Just con my Private CA.
Thank you for your answer, I do not know why my notiifications is disable.
