Does the HDMI output on a C20 Codec carry HDCP?
absoluteAVS1
I need to send the output of a C20 CODEC to both an HDMI source and a VGA source.  Does the HDMI output carry HDCP?
Patrick Sparkman
No it, does not.  I don't have or know of any documented information, but just from within my environment it hasn't reported itself as an HDCP source.
6 Replies 6
Patrick Sparkman
Thank you for your help
vivsing2
Hi Alex,
Right now C series doesn't support HDCP.
Vivek
mubakhta
Level 4
Level 4
Currently this is not supported. We have looked into this, but the licensing doesn't allow us to send HDCP encrypted content to the far end side, even if we re-apply HDCP at the far end. So if we are to implement this we would only be able to display the HDCP content locally to avoid breaking the licensing for HDCP.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Thank you
