Does the MultiSite feature included in Room kit pro?
Lazerunner22
Dear all
Does the MultiSite feature included in Room kit pro? Or Shall I order a license to enable it?I can't find any such license options on the Cisco CCW estimate page.
Many thanks
Robbie
5 Replies 5
Patrick McCarthy
Multisite is an option - it is not included in any room system.
Thanks! So how can I order it? I try but I can't find it, and that also no information including the ordering information.
If you're still having trouble finding it on CCO, you can find the L-KITPRO-MS as a subitem under L-ROOM-PAK.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thank you very much for the top level part number. I don’t understand why Cisco didn’t mention it in Kit Pro data sheet, while just one line above MultiSite there is a Remote Monitoring license with top level part number mentioned in brackets.
