DSCP value
csco11579831
Is there a method to set the DSCP value to 46 without going through the policy-map?
James
Jonathan Schulenberg
On what? the endpoint? a switch? the router?
Endpoints will set the DSCP value based on the Enterprise Parameter config in CUCM
A L2 switch will have a CoS to DSCP map if you're trusting CoS on the switchport instead of DSCP.
Routers must use a policy map.
Please remember to rate helpful responses and identify helpful or correct answers.
my problem is that I can not keep the tag after crossing a switch,
Do you have QoS enabled on both switches and enabled "auto qos voip trust" on the trunk links?
