12-27-2017 08:55 AM - edited 03-18-2019 01:43 PM
I'm trying to setup my DX70 to connect to dCloud using a VPN. According to the instructions, once my DX70 is connected to the Wi-Fi network, I should go to Setting -> More -> VPN.
However, after connecting my DX70 to the Wi-Fi network, I can't find an option to connect it to a VPN.
According to documentation I should have Cisco AnyConnect installed on the endpoint, but I'm unable to find it.
I did convert the DX70 OS from Android to CE a few months ago, perhaps Cisco AnyConnect is not there on CE? In that case, should I convert back to Android or can I still connect to a VPN?
Jacov
Solved! Go to Solution.
12-27-2017 02:33 PM
Correct, the alternative if you use CE code is to use MRA, the VPN client is only available if you use the Android FW.
12-27-2017 02:33 PM
12-28-2017 04:54 AM
