E20 My Contacts
Hi.
If i add a contact to "My contacts", i cant remove it from there.
Steps to reproduce:
1. navigate to corporate phonebook
2. enter contact details
3. choose "Add to favorites"
4. confirm dialog
5. navigate to "My Contacts"
6. choose recently added contact
7. enter into details
8. choose "remove from favorites"
9. confirm
10. check "My contacts", the contact is still in there!
They could only be removed via CLI.
Ashwani Pande
Yes it will always be there as you have removed the contact from favorites but not from "My Contacts".
To remove the existing contact entry.
1 - Navigate to My contacts.
2 - Select the contact you would like to delete.
3 - Select "Edit the contact details"
4 - Select "delete contact"
It will help us in deleting the entry from My Contact.
please let me know if it helps you in resolving the issue.
Ashwani Pande
Thanks, it worked.
non-intuitive though.
