Edge75 power supply
Customer has some Edge 75's that need power supplies replaced but they were not on maintenance.
Does anyone have the partnumber to order?
Thanks.
6 Replies 6
Tomonori Taniguchi
The PID of current AC adapter for Edge 75MXP (CTS-EDGE75-K9) is “PSU-12VDC-50W=”.
Previous version model is “SA150B-12V” but has been replaced with new model.
Could you please tell the part number of power supply for Edge 95MXP. I did not find  “PSU-12VDC-50W=” in Cisco GPL.
Thanks.
PSU-CAM-V=
br Oleksandr
Thanks Oleksandr
Does the "PSU-CAM-V=" work with all Tandberg EDGE series?
Is there an official announcement about this replacement?
The old MXP series endpoints are all end of sale, so it won't be possible to get direct replacements for any of their parts, which is why some have used other power supplies such as the PSU-CAM-V which is meant for Wave II/PrecisionHD Cameras, as it falls into the 100–250 VAC, 50–60 Hz 45 watts max used by the MXP endpoints.  I happen to have some 3000 MXP endpoints using the same type of power supply as the PSU-CAM-V and there is no issue.
