08-18-2014 05:41 AM - edited 03-18-2019 03:17 AM
we have recently bought Cisco EX90 with software version TC7.0.2.aecf2d9.
We are facing a problem with presentation sharing. When we make a video call and start presentation sharing call suddenly drops. On other side is also Cisco EX90 with same software version. Device is standalone
Could someone help what should i check in device configuration?
Thanks!
Solved! Go to Solution.
08-19-2014 09:13 PM
Are you able to provide some more detail on your call / environment, such as:
Wayne
Please remember to rate resposnes and to mark yoru question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
08-18-2014 11:10 AM
What is the Call control you are using? CUCM/VCS/none?
08-18-2014 06:51 PM
The OP said that the unit is a standalone, so not connected to a CUCM or VCS.
When sharing a presentation, the system will split the bandwidth it is using between the normal video and the presentation - if the bandwidth of the call is too low, I can forsee that the call may drop.
What is the call rate of the call you are making? What are the call stats - is there any major packet drops/jitter/etc when the original call is in process?
Are you able to update to the latest firmware version (TC7.1.4) which includes many bug fixes as well as security enhancements (including fixes for the latest OpenSSL security vulnerabilities).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
08-19-2014 12:59 AM
This is call statistic:
08-19-2014 09:13 PM
Wayne
08-19-2014 11:50 PM
Wayne, thanks for your suggestion. Problem was caused by firewall inspection of RSTP.
Now it works fine.
