EX90 with TC7.0.2 doesn't show meetings on the touch pannel
Afternoon,
Upgrading an EX60 and an EX90 from TC6.3.0 to TC7.0.1 and after to TC7.0.2 (s52000tc7_0_2.pkg) we discovered that after schedule a meeting it doesn't appear on the meetings menu on the touch pannel, I tried scheduling between EX and EX with CTS too and it never appear on the EX endpoints, going back to TC6.3.0 the meetings appear again.
Any knows why is this happening?
Thanks in advance,
Eduardo Vega
7 Replies 7
Martin Koch
Did you check on the logs on the endpint and tms? Also did you check the bug toolkit?
Also a tcpdump could be interesting. Maybe you see something there
Is there a secific reason you need TC7.0.x? In my oppinion TC6.3 seems to run more stable.
Please remember to rate helpful responses and identify helpful or correct answers.
Kjetil Ree
Do the meetings show when you do a "xcommand Bookings List" from the command line? You would expect to see something like this:
If the meetings do not appear here either, check TMS's log-TMSDatabaseScanner.txt.
Kjetil
Afternoon,
Doing that comand we get:
OK
*r Bookings ResultInfo TotalRows: 0
*r Bookings LastUpdated: "2014-02-11T18:40:51Z"
** end
I schedule the meetings through Exchange + Cisco TelePresence Manager.
I tried to schedule a meeting now and it appears on the TC6.3.0 endpoint but doesn't on the TC7.0.2 one.
About upgrading, we just wanted to check the last version.
I see. I don't know much about Cisco TelePresence Manager, so I'm afraid I cannot help you much.
For what it is worth: This document at least shows that TC 7.0 is supported with Cisco TelePresence Manager (>= 1.8). I don't see many CTS Manager related discussions in these support forums, so I recommend opening a TAC case to resolve your issue.
-Kjetil
Wayne DeNardi
It works on EX90s (and other TC software based devices) I have here running TC7.0.2.  It takes around a minute for the meeting to appear on the device after scheduling it in TMS - and same with deleting - it takes a while before it disappears from the list on the device.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
lorenzg
Hello, I'm having this exact same issue and I cannot find any bug open. How did you manage to fix it?
We went back to TC6.3.0 and now we are at TC7.3.2 working perfectly.
