Export local VCS findme accounts
khoabui76
Is there away to export/import local VCS findme accounts and can you create findme account on VCS using command line?
Martin Koch
What do you want to archive?
In general the deployment should be to use TMSPE and just handle provisioning and findme via TMS.
What do you use TMS-Legacy-opends style provisioning or TMSPE?
Which software versions do you run on TMS & VCS
Any special things in your deployment?
You can also rewrite addresses via a CPL or a policy server.
I have a special case where I want to able to export and import local VCS find me account without using TMSPE or Agent.  If I cannot, can i create local findme account using VCS command line?
Hi Khoa,
Using the old style provisioning TMS agent there we have the facility for creaitng the findme accounts locally on the VCS,
However when you migrate on the TMSPE you don't have the facility for creating this accounts on the VCS, infact as Martin said this accounts will be taken care through TMS now.
although the fidme accounts created on vcs locally will remain in the database after migrating to TMSPE.
Rgds
Alok
