Expressway B2B without MRA
anthonykaune
Level 4
Level 4
Is it possible to setup B2B calling through an expressway C and E without setting up MRA?  Obviously the traversal zone can be setup, but I don't think you get the option to add a local domain until MRA is enabled.
Basically they want B2B calling now, and will possibly add MRA later once company policies can be worked out.
Alok Jaiswal
Level 4
Level 4
You can pretty much do that. There is no such requirement that you must add a domain for enabling B2B calls.
Just setup a normal Traversal client (Exp-C) and Traversal server (Exp-E) and then create necessary rules and transforms (if required) pointing to the relevant zones.
Alok
