expressway core "Certificate verification failed"
yerbol
Hi everyone,
I updated expc to version 14.0.6, after the update, this error appeared. How can I solve it, please tell me?
b.winter
Have you read what is stated under "Action" in your screenshot? Everything you need to know is stated there.
check your DNS server >> A records + Reverse Records..
you must both have two DNS record (A + Reverse PTR) for your EXPC FQDN name correctly..
also, check SANs you entered in Certificate of EXPC, maybe its needed to updated or entered new one..
-- if this helped, please rate by click (Accept as solution) or (Helpful) --
