hi, ciscomen!
just trying use tms provisioning extension for movi register
Cisco TelePresence Management Suite Provisioning Extension Deployment Guide
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0_with_14-1.pdf
after installed TMSPE on tms server , the system got some notes and alarms and the vcs provisioning mode is "tms anent legacy “mode but
can not switched to "provisioning" mode
the system log:
"To enable the VCS to import provisioning data from TMS, the VCS Provisioning Mode must be set to 'Provisioning Extension'.
Configure the connection settings and the individual services first and when the status of all the services are OK, the mode can be switched to 'Provisioning Extension'
what should i do??
need your help
