Force FXO Port to Hang up After 30 Seconds
russellhughes1
I have a CISCO2951 with FXO card that is going over to a very old Valcom PagePac controller. For some reason recently the line will not hang up about half the time. I would like to force the FCO port onhook (or to hang up the line) after 30 seconds. What command can I use on this FXO port?
Leonardo Santana
Try this one
voice-port X/X
timeouts call-disconnect seconds
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
FXO disconnect problem is a well known issue. I feel like the FXO is unable to detect the disconnect from Valcom PagePac controller
https://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/8120-fxo-disconnect.html
timeouts call-disconnect seconds For the FXO  to   wait before disconnecting an incoming call after disconnect tones are detected.
https://www.cisco.com/en/US/docs/ios-xml/ios/voice/vcr5/timeouts_call-disconnect_through_timing_clear-wait.pdf
Response Signature
