07-30-2017 01:45 PM - edited 03-18-2019 01:21 PM
Dear All,
I am trying to add new SX10 endpoint to VCS X8.1 . It's not getting registerd with h.323 as Gatekeeper . I am able to register with SIP.Configuration is straighforward i just added in the codec page h.323 Gatekeeper address . It shows inactive. How to fix the issue?
Solved! Go to Solution.
07-30-2017 11:10 PM
You don't mention what software version you are running on the SX10.
H.323 call support was only added to the SX10 from software version CE8.2.0.
You also need to make sure you have enabled H.323 (it is disabled by default) on the Network Services Page of the GUI, or via the CLI with:
xConfiguration NetworkServices H323 Mode: On
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
07-30-2017 09:48 PM
Don't the gatekeeper logs give any clues?
07-30-2017 10:43 PM
I Couldn't find h.323 meessage in diagnostic logs..
Below is the Gatekeeper cnonfiguration
Call Setup Mode:Gatekeeper
Encrypion Key Size:MAX1024BIT
GateKeeper IP:
Port Allocation:Static
E164:212@domain.com
07-30-2017 11:10 PM
Wayne
07-30-2017 11:12 PM
Thanks Wayne [+5]
SX software version is CE 8.2.2 Fina 326v59
Let me try an update you if it works!
07-30-2017 11:29 PM
Excellent Wayne..
It worked for me. The H323 Endpoint get registerd.
Thanks lot for your support.....
