Showing results forĀ
Search instead forĀ
Did you mean:Ā
Video endpoint registered to CUCM I need to make other endpoint video
amr_saudi99
Level 5
Level 5
I have registered end point to CUCM and it is working fine
but I should add @NITC.com at the end of the public IP Address of the video end point.
can I make the dialing directly using the IP Address instead of adding the @NITC.com at the end point.
the call flow
sx20--->CUCM-->Exp-C-->Exp-E-->Internet---> Other end point Public IP.
akoukis
If I have understand correct your request, what you need is CUCM IP Dialing. There is a very detailed configuration example on cisco.com.
Please see the following link
http://www.cisco.com/c/en/us/support/docs/unified-communications/telepresence-video-communication-server-vcs/118884-config-vcs-00.html
Best Regards
Anestis
