H239 Bandwith consumption
What is the bandwidth required for H.239 for Cisco TelePresence MCU, IP VCR and ISDN GW units/blades and the Serial Gateway Series units/blades?
Thx in advance for your responses.
epicolo
Level 3
Level 3
Dual Stream will use part of the main stream bandwidth.
The main stream is the video payload based on the call setup/negotiated bandwidth less audio payload.
You can configure this on the Enpoint, which part to took from the main stream (for example 50%).
384k call (aprox. 460kbps on L2 network)
64k for AAC-LD audio codec
320k for video payload
if configured to use 50% (160k for main video and 160k for dual stream)
