Help upgrading Expressway starter pack
jlcembellin
I have a Expressway starter pack version 5.1.1. Can I upgrade to 5.2 with the same options keys?
Someone has made this upgrade?
Tomonori Taniguchi
VCS software upgrade require the “release key”.
The release key for X5.1.1 and X5.2 are same so you can use X5.1.1 release key to upgrade VCS to X5.2.
Option key(s) are remain same and no need to modify during X5.1.1 to X5.2 software upgrade.
