11-07-2024 10:11 PM
Hello everyone, I am installing the CS-CAM-PTZ4K camera for the conference room, but when I ordered it, I forgot that it was ceiling mounted. Now I want to process the bracket to hang it on the plaster ceiling, but I can't find the drawing to go to CNC machining. Can everyone help me with the drawing or is there a way to safely hang it on the ceiling?
11-08-2024 11:39 PM
I’m not sure if there’s a CAD file available for use in AutoCAD, but you can find the CAD drawing at this link
11-26-2024 07:56 PM
It just mounts via the standard 1/4 20UNC thread, so as long as you have a suitable bracket that will support that size fastener through it into the camera and that will support the camera's weight, you should be good.
Please remember to mark helpful responses and to set your question as answered if appropriate.
