How do I completely disable ADB on an DX80 without Cisco UCM?
philekiert
Question's pretty much in the title, I can't seem to find any way to do this through the API or the web interface. Hopefully I'm just being blind.
We could just put an anti tamper label over USB ports, but it'd be nice to completely disable it for added security.
Anurag Srivastava1
Android based DX80 software is already announced EOL please see the below link-
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/desktop-collaboration-experience-dx600-series/bulletin-c25-738941.html
If you don't have any particular requirement to use android then you can convert it into CE version. Below is the link
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/dx/dx70-dx80/dx80-dx70-convert-between-ce-and-android-based-software.pdf
If you don't have UCM then see section" Migrate a DX device to CE software with no Cisco UCM"
Please rate if it is helpful.
Please rate if it is helpful and mark as accepted solution if applicable....
Anurag Srivastava1
Ah! Clearly I didn't read enough, I was wondering why I couldn't find anything about it in the documentation. We're already on CE, thanks for your help!
