CMS Webrtc username different domain
csrlima
Level 3
Level 3
Hi, i have a Cms with different domain from AD domain and integrated with AD by LDAP, so When user uses webrtc it works if he puts is user@cmsdomain but he Would like that username was user@ADdomain , equal to username in AD or if he could put only username without @domain. Any sugestion?
Georg Kehrer
Level 4
Level 4
Hello
You must configure CMS with XMMP Multidomain
4.5.1
Configuring XMPP multi-domains
A single XMPP server can host multiple XMPP domains. For example, both example.com and example.org can exist on the same Meeting Server. It is possible to configure multiple tenants with the same XMPP domain (as in previous releases), or each tenant with their own domain, or mix these schemes.
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Deployment_Guide/Version-2-5/Cisco-Meeting-Server-2-5-Single-Split-Server-Deployment.pdf
After that you have the possibility to login via webRTC with different Domain wich you have added.
Best regards
Georg
5 Replies 5
Georg Kehrer
Level 4
Level 4
Hello
4.5.1
Best regards
Georg
Its already working , I created a different domain for xmmp as you told me , and worked!
Thanks a lot
perfect! great to hear is working.
Best Regards
Georg
how did you get this working
have tried using xmpp multi domain add
not workinh
try to analyse with >syslog follow
and then login with the differetn domain, maybe you will see that DNS entry is not made for the additional domain.
or did you get the failure if you start XMPP ?
BR
Georg
