How many licences do i need ? [mse8510]
Dawid Prus
Hi.
Please tell me how many licences do i need, to meet this requirement on MSE8510:
- max 96 audio only connection / 24 SD connection
"/" - means OR (not together)
Is it possible on only 1 blade ?
I can't find how to count audio connection
Thanks.
Dawid
Patrick Sparkman
Hello Dawid -
Take a look at the MCU Port Matrix in the admin guide, p224.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/mcu/admin_guide/Cisco_TelePresence_MCU_4-4_Product_administration_guide.pdf
You won't be able to get 96 audio only ports with one blade, you'll need to add another blade and either cluster them together or create a cascade link between them.
You can get up to 80 SD ports though.
