How run report in TMS to collect endpoint serial numbers?
jtreyes
Greetings Cisco Community,
I have TMS v15.4.0 at the moment and I would like to run a report (ie. export into Excel) that collects all the hardware serial numbers of all endpoints and MCUs.  I did execute a report from 'Reporting' > 'System' > 'System Connection' but the report included "System ID", "System Name", "Network Address", "Specific Type", "System Name", etc, but no "Hardware Serial Number".
Is it a matter of creating a custom template or other?
Thank you!
2 Accepted Solutions
JFerello
See attached.
Justin Ferello
THANK YOU so much JFerello!  Worked like a charm.  You have been most helpful.
JFerello
See attached.
Justin Ferello
Hey man, do you know How run report in TMS to collect endpoint down time?
