How to call from Cisco SX 20 to Room on MCU Polycom have password?
nguyenngoctuyen
Hi experts,
I want to call from SX 20 to Room on MCU RMX 2000 of Polycom, how do i do?
EX: Room ID on Polycom: 8888, Password room: 123456
Thanks!
5 Replies 5
nguyenngoctuyen
I call follow H.323 protocol, please help me!
Cisco video endpoints used the URI dialing method "E.164number@IPaddress".
E.164number = 8888
IPaddress = 192.168.x.x (IP address of the MCU for example). You should know the IP address of the Polycom RMX.
If you have the Polycom Room ID "8888" which is an registered alias of the MCU, from SX20 dial 8888@192.168.x.x. Then you will be asked for the PIN/Room password, enable DTMF and enter 123456 to connect on the conference.
Or you can also try this shortcut method for H323 call - h323:<roomID>**<password>@<MCU_IPaddress>
ex. h323:8888**123456@192.168.x.x
regards,
Acevirgil
***Please rate or mark as correct answer if this post is helpful.
Thanks Acevirgil for your support,
Heretofor, i testing with method SX 20 Cisco call H.323 to Room on MCU Polycom: Room_ID#@IP_MCU Polycom. and success, but with room not set password. Now case, my customer set password for room, i will test with method that your support, hope success!
OK so I tested using an EX90 ,
So what I wanted to do is call a Conf.Room that has a password.
Room_ID#Room_Pass@Public IP
That should get you through.
Dear Acevirgil,
I have Polycom HDX6000 call to Room ID: 111 on MCU 5320 Cisco, room password: 222 Pleasse help me how do i do? what is syntax to call?
Many thanks!
