02-23-2017 10:49 AM - edited 03-18-2019 06:56 AM
I what to use a dx80 with a generic sip server
02-23-2017 12:44 PM
You need to switch it to CE8.3 if it's still running Android OS (android is CUCM only). From there take a look at the CE8.3 admin guide on configuration, it's all in there.
02-24-2017 02:37 PM
Hello Patrick, thanks for your answer.
I already upgrade two to CE 8.3, I follow the admin guide, but is not working
they get registered and are able to receive calls, but they can not place them.
I did a capture using extended system log, check it with wireshark and apparently the DX is not sending the call request to the proxy.
Any idea?
02-24-2017 02:48 PM
So your SIP server is NOT receiving the INVITE? Can you share your packet capture of the failed call attempt?
02-24-2017 03:29 PM
02-24-2017 04:42 PM
Using Wireshark, I looked at your .pcap file of the DX80 call. I've attached a screen shot of the Wireshark filtered call.
There are SIP INVITE's going out to 2120@66.226.73.200 with NO response. I see these are UDP packets which might be a problem. What if you set your SIP DefaultTransport to TCP?
You could also see if there is some router blocking the traffic.
02-24-2017 04:49 PM
Thanks Joe, I´m going to double Check it
