How to configure a firewall for a SX20 registered on a VCS Expressway
Hi all,
As you can see in the picture, I have a classic situation. Everything is working properly.
Now customer needs to use a cisco SX20 in a branch office.
The Cisco ASA 5540 firewall is currently configured as follows:
  1. static (inside, outside) 213.42.140.136 (public ip) 10209252166 (internal ip)
  2. access-list extended permit ip host 87.241.12.76 OUTSIDE_access_in (VCS Expressway IP) host 213.42.140.136
I have done many tests:
  • SX20 H.323 configuration whit Nat On, Off and Auto
In all cases the system is recorded correctly, but the call signaling does not occur.
  • If instead of using my own system with a public IP it works fine.
Can anyone help me how to properly configure the firewall?
thanks in advance
Check on the asa that threre is no fixup / inspection enabeld for sip, h323 and skinny.
You find a doc regards voip and ASA here:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
6 Replies 6
Michael Boscia
Level 4
Level 4
What does the ASDM on the firewall say in terms of logging of blocked traffic when it doesn't work?
Michael Boscia
Level 4
Level 4
The firewall manager, says that there are no packets dropped.
thanks for the quick response
Michael Boscia
Level 4
Level 4
What log level are you looking at?
Does it show the packets getting through?
Thanks Martin
Following the guide  that you suggested I configured the firewall and now everything is working properly.
Best Regards
