How to Connect Cisco Table Microphone 20 and DX80
Hashimhbk
How to Connect Cisco Table Microphone 20 and DX80??
Dx80 Have only one USB Port ?
Any Solution?
PJMack
Level 7
Level 7
The DX80 has two USB ports, one in the back, one on the right side. That said, you're asking about Table 20 mic, that requires a microphone port, not USB, and there are no mic ports on the DX80. I'm curious on why you would need a mic for a system with a 23" screen and built in mics? In any case - you could use a device that connects like a headset - one of the Jabra "Speak" models, but that will effectively move your audio out as well as in - perhaps that's what you want/need? If so you should check those out.
Wayne DeNardi
In short - you can't.  The DX80 is not designed to have one of the table microphones connected.
If you need to use external microhones, then your best option is to use a bluetooth device that supports the HFP (Hands-Free Profile) or A2DP (Advanced Audio Distribution Profie).
If you're getting to the stage where you are moving that far away from the device that the internal mics are unable to pick you up clearly, then you are probably better off using a different model endpoint than fiddling around trying to make the DX work (such as the Room Kit series).
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
