How to delete the LDAP imported users in CMS | AND how to backup the running configuration of CMS
Ibrahim Jamil
Level 6
Level 6
Hi Guys
1. How to delete the LDAP imported users in CMS
2. how to backup the running configuration of CMS
thanks all
Anurag Srivastava
Hi Ibrahim,
Answer- The only way is to delete or move the particular user from active directory from which you are pulling the users to CMS. And when you sync it again it will be removed from CMS as well.
2. how to backup the running configuration of CMS.
Please refer the below link-
https://video.cisco.com/detail/videos/collaboration/video/5820051825001/how-to-backup-the-configuration-of-a-cms-cisco-meeting-server?autoStart=true
Please rate if it is helpful.
Thanks.
Hi anurasr2
thanks
now how to restore the backup conf to CMS ??
thanks
Hi Ibrahim,
So once you have the backup file, you can run the below command to restore-
bcakup rollback <backup file name>
And this will restore your config.
You can refer the MMP  guide (Backup and Restore System Configuration - Page 56)
https://www.cisco.com/c/dam/en/us/td/docs/conferencing/ciscoMeetingServer/Reference_Guides/Version-2-3/Cisco-Meeting-Server-MMP-Command-Reference-2-3.pdf
Please rate if you find it useful.
Thanks.
