11-16-2018 12:52 AM - edited 03-18-2019 02:27 PM
Hi Guys
1. How to delete the LDAP imported users in CMS
2. how to backup the running configuration of CMS
thanks all
11-21-2018 11:29 PM
Hi Ibrahim,
Answer- The only way is to delete or move the particular user from active directory from which you are pulling the users to CMS. And when you sync it again it will be removed from CMS as well.
2. how to backup the running configuration of CMS.
Please refer the below link-
Please rate if it is helpful.
Thanks.
11-22-2018 12:34 AM
11-22-2018 01:01 AM
Hi Ibrahim,
So once you have the backup file, you can run the below command to restore-
bcakup rollback <backup file name>
And this will restore your config.
You can refer the MMP guide (Backup and Restore System Configuration - Page 56)
Please rate if you find it useful.
Thanks.
