How to do Hard rest to C60?
Shy Solenko
Somwone can tell how to do hard reset to C60?
The C60 does not have a button like this, but it might be in the future, who knows. For the time being if there is no other option (like the CLI factory reset command) you have to use a console cable and perform a set off commands or you can even re-install the software from scratch using a TFTP server.
More about this in this thread where they are discussing different ways of doing this:
https://supportforums.cisco.com/message/3757496#3757496
Do you just want to know if it has a button or do you actually have to factory default one of your C60's? BTW the thread is for C90 but its valid for C40, C60 and C90.
/Magnus
5 Replies 5
Shy Solenko
I mean to hard factory reset.
Do you mean the Factory reset option that is available from the WEB interface, under the maintenance tab?? or from the command line via SSH??
I mean like in the Sx20 you can press 10 seconds and then after the syste, starts blinking you press twice on the "on" buttton.
I like to know how to do it in C60?
/Magnus
Got it
