How to enable HTTPS login access to VCS 8.x
marco_81
Hi all,
i was trying some settings on Cisco VCS and absently i disabled HTTPS access to login page. So now i cannot access to web gui. Is it possible to enable HTTPS again from CLI?
thanks
Wayne DeNardi
The CLI command you are looking for is:
xConfiguration Administration https Mode: On
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Joe Vallender
Level 3
Level 3
Are you able to SSH into the VCS?  There may be an xconfiguration command to turn on https access.
Wayne DeNardi
Wayne
yes i'm able to login as admin via SSH, then perform the command you suggest and then a restart and all is it. All CLI commands are available on VCS Administration Guide. Remember to login ad admin and not as root.
thanks.
