how to forward incoming primary isdn calls to different internal directory numbers?
vistaprogrammer
Dear All:
i have installed new isdn pri line in our cisco router 3845 ? and it is working fine for voice
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
voice-port 0/1/0:15
timeouts interdigit 3
timeouts call-disconnect 5
timeouts wait-release 1
connection plar 100301
the isdn pri number is (2181700-2181799)
all the calls in this case is forwarded to the internal directory number (100301) and this is working perfectly ?
how can i forward the different called numbers to different internal directory numbers , for example"
forward incoming call for 2181706 to the internal dn 100301
forward incoming call for 2181707 to the internal dn 100302
and so on ...
please help
Vivek Batra
You need to use translation rules and profiles.
For example;
voice translation-rule 1
 rule 1 /^2181706$/ /100301/
 rule 2 /^2181707$/ /100302/
voice translation-profile PSTN
 translate called 1
voice-port 0/1/0:15
 translation-profile incoming PSTN
- Vivek
8 Replies 8
Vivek Batra
For example;
 translate called 1
voice-port 0/1/0:15
- Vivek
Thank you Vivek for your reply
i tested it ..it is working ...you are great in helping me and straight forward...appreciated...
regarding Jaime , i would be appreciated to complete the Suggestion to be more useful
anyways i will complete my questions in the IP Telephony section as you Said.
Finally , Thank you Cisco ...for this Great Support Community Site
Best Regards,
Basel
You are most welcome Basel. Glad to know that solution worked for you.
- Vivek
Jaime Valencia
This is the Video Over IP community, I suggest you move this to a relevant area
java
if this helps, please rate
kindly note that the question is voice over ip ....
it is related to forward the isdn call to internal directory number considering voice gateway and Cisco call manager dial plan ...
so what the relevant area you Suggest!!!
Jaime was suggesting to move it to IP Telephony section.
- Vivek
Take another CLOSE look at what I posted, I did NOT say voice, but video, this area is dedicated to video over IP questions. Compared to IP Telephony, or other communities, this community does not have as much traffic, and thus, less people will see your post. That's why it's important to post in the right area.
java
Anyways i would be appreciated if you direct me to the relevant area since i did the mistake in the post place ,but Vivek did ,and directed to the suitable place..
that would be more useful ...
also Vivek helped me in my question and get me to the solution even in video community
Thank you Vivek...
