ā09-03-2017 07:51 AM - edited ā03-18-2019 01:26 PM
I add users in LDAP, and imported into TMS mannually, but I can not find configuration to synchronize users automatically. for example, synchronization every 30 munites.
I use TMS for device provision ,so I must import users inforamtion into TMS.
Solved! Go to Solution.
ā09-04-2017 01:17 AM
I think i got what you are asking for. TMSPE sync the users everyday, its an automated process which runs in the background. You can't change the time of this, but you would be able to see the update happened.
Systems-->Provisioning-->Users
Alok
ā09-10-2017 05:17 PM
I find a workaround solution for synch automatically.
I run Chrome browser and open the user window, then I open Console window, I edit a script program that refresh the browser every 10 munites.
the user information can synch with oPenLDAP automatically.
ā09-03-2017 10:39 PM
As far as i remember its always manual sync. So when you make changes you run a user sync again.
regards,
Alok
ā09-04-2017 12:20 AM
Is there API that can trigger sych?
ā09-04-2017 12:35 AM
I find the discussion that is
Could you help me to check it.
Alok
