How to synchronize user data to TMS from LDAP automatically?
xujf
I add users in LDAP, and imported into TMS mannually, but I can not find configuration  to synchronize users automatically. for example, synchronization every 30 munites.
   I use TMS for device provision ,so I must import users inforamtion into TMS.
2 Accepted Solutions
I think i got what you are asking for. TMSPE sync the users everyday, its an automated process which runs in the background. You can't change the time of this, but you would be able to see the update happened.
Systems-->Provisioning-->Users
Alok
I find a workaround solution for synch automatically.
I run  Chrome browser  and  open the user window, then  I   open Console window, I  edit  a script program  that refresh the browser every 10 munites.
   the user information can synch with oPenLDAP automatically.
5 Replies 5
Alok Jaiswal
Level 4
Level 4
As far as i remember its always manual sync. So when you make changes you run a user sync again.
regards,
Alok
Is there  API that can trigger sych?
I find the discussion that is
"TMS Provisioning, synchronize AD user not automatically".   it seems ok to  synchronize automatically.
Could you help me to check it.
Alok
