06-14-2011 06:30 AM - edited 03-17-2019 10:20 PM
Hi!
Our final goal is to get access to Cisco TAC. We are/were TANDBERG certified partner. Now, we don't have any acces to TAC cause we don't know the NEW contract number of our Customers. We tried to update them in the Profile Manager, but does not work. ¿Who can help us to fix the problem? We have Serial number's; in TANDBERG world the serial numbert was enought to get acces to TANDBERG's TAC. Finally we have problems with Movi Integration from internet Access.
Waiting, for coment's...
06-15-2011 06:51 AM
Have you met your Channel/Partner Account Manager (PAM) yet? There's a lookup tool if you're unsure who it is: http://tools.cisco.com/WWChannels/CAMLOC/jsp/cam_locator.jsp
They would probably be your best bet to get this straightened out. If that doesn't work the Partner Relations Team would be your next bet to get connected with the appropriate resources.
06-17-2011 01:07 AM
You can access TAC as long as you have a valid service contract
If you had previously service contract active on your devices, all those service contract should have been migrated to the new CISCO tools, and you should have received a "welcome letter"
This was supposed to be something around those words :
The combination of the Cisco and TANDBERG portfolio of products and services brings superior experience and innovation to business video systems and networks, and the next step of integrating our technical support tools and processes will help ensure that we address your needs more quickly and effectively.
Looking forward, our goal is to empower you to effectively manage service renewals and support requests for products covered by service agreements with Cisco. As for the service that follows each request, you can count on the same responsive and thorough support that you have always received.
Your New Cisco Service Agreement
The migration of your TANDBERG service agreements has been completed, and your new renewal and support process is effective immediately. You will now use Cisco Service Contract Center to view, manage, and renew services that were migrated into the Cisco installed base system. Although your TANDBERG service agreements will be assigned new Cisco contract numbers, the serial numbers will remain the same in the Cisco tools. You will be responsible for providing service quoting, ordering and support for products to your customers.
Access your new contract numbers in Cisco Service Contract Center by following these steps:
http://www.cisco.com/web/services/ordering/cscc/index.html
Service Support Center
For questions about service quoting, ordering, or contract management, open a case with the
http://forums.cisco.com/ecom/web/service-support-center
When opening a case with the Service Support Center, click "Get Help." Note: In the "Subject" field, include your Partner Company name and when appropriate the Contract Number. In the "Category" drop down, select "General Information" then "TANDBERG". You can also specify "Quoting" or "Support." This will enable agents to quickly recognize and address your question.
Cristian
