07-27-2004 06:53 AM - edited 03-17-2019 08:14 PM
I`ve got an FXS port which is showing as FXSLS_PARK under "show voice call summary", what`s the easiest way to reset this to FXSLS_ONHOOK without using shut, no shut??
07-27-2004 06:56 AM
Shut/no shut is your only way to reset the port. What IOS are you running? Useful information would be show voice port summ, show call act voice brief, show voice dsp, show voice call sum.
09-01-2004 10:28 AM
I don't know if this help you.
I have a cisco 1760 conected to a Panasonic PBX in this configuration: CO-FXO-FXS-PBX, and the FXS was going to FXSLS_PARK state continuously.
I use "no supervisory disconnect lcfo" on fxs port configuration to resolve it.
02-24-2005 08:22 PM
hi Ribett,
I've the same connection with you. I've a problem: when the receiver on the panasonic pbx site pick-up the phone to answer, he will hear a kind of redial-tone before he can talk to the caller. I've this config on the FXS site:
voice-port 2/0
echo-cancel coverage 32
cptone MY
timeouts interdigit 3
timeouts call-disconnect 5
timeouts wait-release 5
bearer-cap Speech
dial-peer voice 1 pots
destination-pattern 31...
progress_ind setup enable 3
progress_ind alert enable 8
port 2/0
Do you have any idea why I got that problem?
thanks.
