incoming Call forwarding to Cell
fahad.tariq11
Hi Guys i need help in  desperate situation , my problem is i am not able to  forward  calls to  client cell phone , This is not it goes when someoen calls on clients E.164 number the call does not forward to cell phone at at it gives fast busy tone where as if someone calls internally to that extension the  call forwards successfully to cell phone i tried every thing  assistance would be appreciated
jonathanlunt
Whenever you re-direct calls externally you have to also include any translation patterns your system has. So if to call out externally as normal you would press 9 (or whatever patten is implemented), and then type the normal number, you would also have to include the 9 in any re-directs.
Thanks for your response but , but my problem is something else
Jaime Valencia
This is the Video Over IP community, you might want to move this to IP Telephony or some other community.
Also mention what troubleshooting have you done so far?
java
if this helps, please rate
is this on cucm or cme?
have you got relevant trace debugs for the said call/
wht is the value set for 'Block OffNet To OffNet Transfer' in case of cucm.
can you directly reach to that pstn number from the internal phone (where forwarding is configured).
also check if there is any css/partition assigned on the forwarding number  which might not be the same as in the RP/GWY
