Incoming Calls start dropping right after when you pick up the phone
Arsen Gharibyan
THe phone system is managed by Auxion company but i have a QOS on ASA 5510, Phone Company Stating that the problem in Qos or ISP but nothing has been changed in ASA Qos , any ideas if ther is missconfiguration ?
class-map VOIP
match rtp 10000 16383
class-map voip-class
match access-list voip-traffic
class-map CONNS
match any
class-map inspection_default
match default-inspection-traffic
policy-map QOS
class CONNS
  set connection conn-max 2000 embryonic-conn-max 3000
class class-default
  shape average 5024000
policy-map VOIPP
class VOIP
  priority
class CONNS
class class-default
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
inspect tftp
  inspect icmp
  inspect ip-options
  inspect pptp
class VOIP
  priority
class class-default
  user-statistics accounting
Arsen Gharibyan
http://www.neocomp.com/
Curtis Fuentes
This usually means a codec mistmatch. do you have any logs ?
justindunkerley
If a call sets up ok and then drops it may well be a codec negotiation issue.
What about the conf above ? do u see any wrong configurations ?
the problem was in latency (Time Warner) and in the codec
Curtis Fuentes
