Installation CE-Console 8.1 failure
Thorsten Borbe
Hi all,
I got an error-message if I install the CE-Console Version 8.1: Invalid or corrupt jarfile.
I tested with admin-permissions and on another computer. It´s Java 8 Update 91 installed.
Is there anybody able to run this software ?
Kind regards,
Thorsten Borbe
Patrick Sparkman
I don't have any issue running the .jar version of the CE Console 8.1.  I'm running Java 8 Update 91, same as you.  Try downloading the file again, maybe your download is corrupt.
EDIT:  Just found bug CSCuz40390, appears TC Console 7.3.3 is corrupt on Cisco.com, might be the same issue with 8.1 as well.
