MCU with VFO deployment is quite simple but need to be careful that only allow to configure default gateway on one of port (either port A or port B).
If any additional routing is require, then you must configure static route under “Routes” configuration.
With VFO, you need configure...,
- Port A
- Port B
- Routes (define default gateway and static route and any additional static route as needed).
- Services (define what service to be enable on each port)
- Gatekeeper (under H.323) define port to be used
