Integration between VCS-C and CUCM
startryst
A few weeks before, it's working when the Movi(reside in VCS-C X7.2) calling Cisco Jabber for Windows(reside in CUCM 9.0), and I did the integration configuration according to the below link:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf
but recently, I found the Movi couldn't reach the Cisco Jabber for windows when dialing the 4 digit extension, I did an re-check for both configuration on VCS-C and CUCM, it looks fine.
So I did an debug in VCS-C, and found below feedback which might be the core issue, but anyone could can point me an insight on this? But what's the problem?
2013-02-02T14:21:45+08:00 vcsc tvcs: UTCTime="2013-02-02 06:21:45,545" Module="network.sip" Level="INFO":  Src-ip="cucm's IP"  Src-port="5060"   Detail="Receive Response Code=503, Method=INVITE, To=sip:1001@xxx.com, Call-ID=765ff5ae569b7e87@172.17.0.14"
2013-02-02T14:21:45+08:00 vcsc tvcs: UTCTime="2013-02-02 06:21:45,546" Module="network.sip" Level="DEBUG":  Src-ip="cucm's IP"  Src-port="5060"
SIPMSG:
|SIP/2.0 503 Service Unavailable
Via: SIP/2.0/TCP cucm's IP:5060;egress-zone=CUCMNeighbor;branch=z9hG4bK45fb9fc08a40a84d401ea90f3b71e053324163.aec65039ec6c7ba030da8842cd0403d3;proxy-call-id=d15db2d6-6d00-11e2-9a66-000c29f34519;rport,SIP/2.0/TLS 172.17.0.14:51949;branch=z9hG4bK8f6932314ce68712d4645221ac36e661.1;received=Movi's IP;rport=51949;ingress-zone=DefaultSubZone
Call-ID: 765ff5ae569b7e87@172.17.0.14
CSeq: 100 INVITE
To: <sip:1001@xxx.com>;tag=105854~d841f777-9ff4-458e-bf52-e8ed52c35ecc-28265121
Date: Sat, 02 Feb 2013 06:21:45 GMT
Allow-Events: presence
Reason: Q.850 ;cause=41
Content-Length: 0
gubadman
Level 3
Level 3
Has anything changed on the CUCM recently? That is a temporary failure message coming back from CUCM. you'll probably need to use the real time monitoring tool on CUCM to really see why it is rejecting the call.
Guy
there isn't any change on CUCM indeed, anyway, I'm installing the RTMT to check...
see below for what I got from RTMT
another one....
