IP Direct Call Error with Roomkit EQ
soohyung choi
Roomkit EQ
RoomOS 11.9.3.1
Configuration / H323 ->CallSetup Mode: Direct
Configuration / NetworkServices-> H323 Mode: On
If I try IP Direct Calㅣ, there is a problem.
Dial command failed. Error: Unknown error
Roomkey Pro fixed the issue with a factory reset (Room OS 10 version) after downgrade.
I have been trying to fix the Room EQ issue, but Cisco have been not providing RoomOS 10 for Roomkit EQ
Is there a solution?
soohyung choi
I solved  "Dial command failed" Error with TAC's help
TAC advice is " Setting admin password " in this RoomOS version (and Register call)
After setting admin Password, this problem was preprectly solved.
Good luck, Regard
soohyung choi
Good luck, Regard
dhanley
This solved our issue as well. seems it presents for devices assigned to individuals instead of shared board.
