IpTv + XP
akaali
Our IpTv servers run under Win2k adv.serv..
Will it work under Win Xp? What dou you mean?
thx,
Akos
Not applicable
Yes you can, Per the release notes, 3.4 is when the client introduced Windows XP support.
Please refer to the following doc on how to install it
http://www.cisco.com/en/US/products/sw/conntsw/ps1869/products_user_guide_chapter09186a00800d9a2b.html
Also refer to the another thread on the same topic which discusses about a couple of problems you might face when doing the installation
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.ee88314/0#selected_message
scottmac
Level 10
Level 10
The CLIENT is OK for Windows XP, but the server (if I recall correctly) is not.
The current IPTV Server or Content Manager software has not been certified for use on XP (which would have a user connection-count limitation).
The new "Pizza Box" IPTV servers do not have CDROM drives or floppy drives. Getting a new OS installed would be a little tricky.
FWIW
Scott
