Is compositing available when dialed into a TMS bridge
Tim Cappel
Level 5
Level 5
I have a C60 with compositing enabled.  When you do a point to point (via Jabber, or Endpoint) it works fine for the far end.  When you dial the C60 into a bridge on our 8510 blade it only shows one of the cameras, like the compositing is disabled.  Is there a setting I am missing on the MCU side?  Any help is appreciated.
Thanks, Tim
Wayne DeNardi
Hi Tim.
Yes, the compositor does work when connected to a bridge.  We use it that way quite often to display two, or three inputs from our C60s to multiple parties, content recorders, etc.
There's nothing special that we needed to do on the MCU to make this work.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
