05-24-2013 06:12 AM - edited 03-18-2019 01:10 AM
Hi everyone,
I'm new to the video/telepresence/H323/SIP word.
I know that it's now possible (and recommended) to register EX60/90 on the CUCM natively, that is to say as Telepresence devices (either with TC or TE firmware) and support full functionnality as opposed to being registered as a SIP Device but still .. is this just possible and what is the configuration?
Here is the final scenario, the SIP registration is a test related to this scenario :
- CUCM version 7.1.5
- MSE 8510
- EX60 TC 5.1
- Jabber clients registered on CUPS
My customer wants to make point to point calls between the EX60 and Jabber clients.
Two possibilities :
1 -
- EX60 registered as H323 device on the MSE 8510
- SIP Trunk between MSE 8510 and CUCM
- EX60 and Jabber clients can call to each other through the SIP Trunk
2 -
- Since the customer only wants point to point calls, i just thought I could register the EX60 directly to the CUCM as a Third Party SIP Device (Advanced since I need video calls). The CUCM version is 7.1.5 so i cannot register it as a EX60 device. What do you think?
3 -
- What about H323 registration on the CUCM ? Is CUCM considered a H323 gatekeeper or do you need an external gatekeeper. What is the point of having an H323 client registered (or created as a device) on the CUCM?
Thank you
Solved! Go to Solution.
05-24-2013 08:08 AM
Hi Matt
Please refer to
https://supportforums.cisco.com/message/3671155#3671155
https://supportforums.cisco.com/message/3919058#3919058
hope this solves your first query.
3> H323 registraion on CUCM , i not sure if i am 100% correct however there is an option of configuring a H323 gateway on cucm
you can created a h323 trunk
there would be a better support 8.6 onwards
rest i will leave for cucm experts to comment upon
Ravi Kr.
05-24-2013 08:08 AM
Hi Matt
Please refer to
Ravi Kr.
05-24-2013 08:41 AM
Hi Ravi,
thank you for the links.
I made the SIP registration working with choosing "Standard" as the type of Proxy (as opposed to "Cisco" when I tried it at the beginning). I think that the "Cisco" Proxy type is maybe only necessary when registering natively (with a EX60 Device type as opposed to a SIP Thrid Party).
I also need to choose TCP (when set to UDP or Auto it doesn't work).
05-24-2013 08:48 AM
Hi Matt,
My pleasure
yes you would have to chose the TCP mode. in some occasion it works fine on Auto as well,
connect explain why ? that why provided you both the methods as we hev selected the TCP in the second link.
hope the infomration provided helped you configuring your EX60.
Ravi kr.
05-25-2013 12:09 AM
Hi Matthieu,
besides from thread link provided to you by Ravi, you need to make sure that Digest user is created on CUCM for authentication purpose.
05-30-2013 08:25 AM
Hi Matt,
i hope your query would have been resolved by now, please mark this thread as answered yes or no
Ravi Kr.
