Hi all,
I have the following setup:
Two Cisco 2911 w/ IOS 15.1(2a)T. Each router is connected to the PSTN via one E1 connection. Both E1 are from the same provider and use the same number range. This means for incoming ISDN calls, I cannot predict and/or control where the call arrives - it's either router one or router two.
Is it possible and supported to run H.320 with ISO/IEC-13871 bonding in this scenario?
My concern is that some of the secondary B-channels might be received be the "other" 2911..
Any thoughts on that?
Best regards,
Steffen
