ISDN Link questions
p.marovino
Hi there,
I have a couple of questions about the ISDN Link:
  • is it possible to pair the SX10 with the ISDN Link?
  • Is it possible to use the ISDN Link for more than one device? i.e. paring the devices via LAN instead of using a dedicated connection.
The scenario should be: two rooms, one equipped with a SX20 and one with an SX10; both should go in ISDN via the ISDN Link, obviously not at the same time.
Thanks in advance for your reply
Paolo
Marius Nedregaard
1) Isdn link cannot be paired with SX10
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=sx10%20isdn%20link
2) You can use the ISDN link with as many supported devices as you`d like, but only one at the time.  You cannot have a C60 and EX90 at the same time
You can pair it over LAN.
If you want more than one device you would need a ISDN Gateway
//Marius
Marius Nedregaard
//Marius
Hi Marius,
thanks a lot for your reply.
Paolo
