isdn to sip message caller id
thanseman
All,
I need to run this by everyone and see if someone has any idea's. I have a asterisk server setup and currently am receiving the inbound calling number where the name should be. My setup is....
One pri terminating into a Cisco 2431 router
Sip messages from the Cisco get sent to a asterisk server
linksys ata's a each remote end.
I can receive the calling name if the call originates from another extension on the asterisk server, I also can "make" the Cisco send out a generic name to the asterisk sip server and I see the name I statically assign in the Cisco appears on the terminating end (linksys ata)
I use the command in the Cisco under sip-ua
calling-info pstn-to-sip from name set name
timers buffer-invite 5000
I have also tried to add the commands...
remote party-id
-voice service voip,sip
ds0-num
Basically I need to take the field Remote-party id and place it in the sip message "From"
Here is some debug from the sip messages in the Cisco... this is an example of "no caller id Name"
ATTACHED IS A MY CONFIG AND SOME SIP DEBUG MESSAGES
b.hsu
Level 5
Level 5
Possibly it's due to a bug CSCeg80858
b.hsu
Level 5
Level 5
thanseman
That did it!, Thanks.
FYI I had to use the command \....
sip-ua
remote-party-id
